polaco
I've posted this in another thread and got no answer, maybe it was too hidden down in the thread. Maybe someone can help me
I've been experimenting with component also. I have a Loewe Xelos (scart) connected to a Toshiba 210 via component (3xRCA), using a cable I made, because I couldn't find a cable that would do it (seems this QED one is new). The Loewe is set at "sync on Y".
The problem is that the TV doesn't switch automatically between 4:3 and 16:9 anamorphic image. What am I doing wrong?
- I should make a cable with 3 RCA for YUV and another one for composite and set the Loewe for "sync on composite" or
- The sync has nothing to do with the automatic switching?
The component out on the Toshiba is interlaced, of course. The TV switches fine using s-video. The picture is fine as it is, just doesn't switch.
