Lodos DVd Player from Sainsbury
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Roger G Cam, Feb 13, 2005.
  1. Roger G Cam
    Roger G Cam
    Hi.
    Sainsbury had/have a DVD player by Lodos. Does anyone have a hack that will turn it into a Multi-Region?
    Or can anyone suggest who really made it? Searching around I get the feeling they are just a badge for lots of other manufacturers and I really need to be looking for some other product/model?
    I suspect the best solution will be to go out and buy an equally cheap multi-region player - but it's not my DVD player.....just trying to point a friend.
    Any suggestions for places I should go and look - gratefully accepted.
    Roger
