locked Grundig car radio !
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by docspawn, Sep 17, 2003.
Thread Status:
Not open for further replies.
  1. docspawn
    docspawn
    Mar 27, 2003
    164
    UK
    +23
    I have a Grundig car200 stereo that has a locked
    code on it, is there any way to reset it ?
    I think i've found the correct code now but after leaving
    it for weeks it still wont accept it !!
    All cause of a new battery !
    Cheers D.S.
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    I've found disconnecting and reconnecting the battery a few times can automatically reset a Grundig radio & you don't need the code - works on some of the Ford ones anyway. ;)
  3. docspawn
    docspawn
    Mar 27, 2003
    164
    UK
    +23
    Thanks for responce , i'll try but not sure if that will do it.
    cheers D.S.
  4. Dave20
    Dave20
    mmm.. so many things it could be.. turn unit on whilst holding AS button.. or having unit on for 2-3 hours usually unlocks
  5. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    If true, it makes a nonsense out of security.
  6. Ayub
    Ayub
    Oct 15, 2003
    6,405
    Bradford
    +583
    dont know if this thread needs answering :
    you switch the unit on within 3 hours it "resets" itself HOWEVER if you enter the INCORRECT code 3 times it shuts down and you have to "resets" the unit.
    Thats done two ways
    A reset code by Grundig who send you the same unit back with the same code as it was shipped with.
    B Go to a radio repair place who charge you a tenner and "decode" the unit by whiping off the existing code and installing a new one OR by REMOVING the code.
  7. Fernsehman
    Fernsehman
    Only a tenner? !!!
    My local shop charges £15 - £20 dependent on model.
    Mind you, I know for a fact that he's so far spent at least £2500 on the decoding equipment and adapters, plus £800 for the PC, so I suppose I shouldn't complain.
  8. Ayub
    Ayub
    Oct 15, 2003
    6,405
    Bradford
    +583
    i was told the equip is £800 and will work off any standard entry 166. Comes with all prongs and free updates.
  9. IANOLIVER
    IANOLIVER
    Sep 28, 2008
    173
    +23
    The correct way to enter the code on a Grundig CAR 200 and most other Vauxhall units is as follows.
    Turn the ignition key on, it must be on to enter code.
    Press and hold in the AS button and then turn the unit on, let go of the AS button after about 5 seconds.
    The display should show 10 ----
    Enter the code and press the AS button for a few seconds.
    If the display shows any other number followed by SAFE then the unit is in error, ie 8 SAFE
    Turn the ignition key back one position but do not turn the unit off.
    Wait for the error to clear. When cleared the unit will show the number followed by ----. Enter the code and press and hold in the AS button.
    9 and 8 SAFE are a 10 second delay, 7 is 10 mins, 6 is 20 mins and 5 is 40 mins etc.
  10. chrisss3
    chrisss3
    Jan 26, 2009
    although this is not what i actually asked for but enlightening imformation... i was actually asking fot the radio code... if that is possible...
    thanks
  11. Flimber
    Flimber
    Sep 22, 2002
    13,369
    Yorkshire
    +4,478
    Not on this forum :lesson:
Thread Status:
