Sinialtstar
Established Member
- Joined
- Nov 23, 2010
- Messages
- 135
- Reaction score
- 22
- Points
- 36
Hi all
Windows 10, Fully updated, virus/malware scanned etc
Strange issue, I used to previously lock the PC (Ctrl, Alt Del) and you would get the lock screen for about a minute or so. Then it would switch off the monitors, into standby – great!
You would then move the mouse, or press “any key” to wake the pc back up again and log in using a password –
However, I cannot pin point when this changed but now it will basically will go into “sleep” as expected, but immediately “wake back up” again and just cycle through sleep, wake, sleep, repeat.
I have a wireless mouse, so I switched it off thinking this may be it, and waited for it to “sleep” but it just did the same.
I have not tried doing the same with the keyboard yet.. but is there something else it could be?
Kind Regards
Kind Regards
