Local Network turning off
Discussion in 'Desktop & Laptop Computers Forum' started by tim k, May 18, 2005.
  1. tim k
    tim k
    I have a wi-fi router connected by usb to my computer, and when i leave it for a long period of time it seems to lose connection and the local network light goes out. The broadband link is still there. Does anyone know why this is?
  2. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +19
    Take a look at the power saving settings, maybe somethings going into standby?
  3. stripe
    stripe
    Apr 7, 2004
    1,241
    Scotland
    +123
    There will be a "not used for" timer in the router which drops everything if it's not used for a certain length of time, just go into the router and set this for as high a time as you can.
  4. tim k
    tim k
    I have checked the power options, reset to always on with no cut offs, i cant find any cut off settings in my router (bt 1250) and its still happening, say about an hour it cuts off. really annoying when downloading over night. any other ideas please?
