For Sale Loads of computer parts (Corsair RAM, Fractal, Noctua, Stark External drive and more)
Discussion in 'Archived Classifieds' started by pop80_uk, Aug 16, 2018.
  1. pop80_uk
    pop80_uk
    Aug 21, 2008
    8,756
    +503
    Ok, so after a rebuilt of one PC and a break down of another I have the following for sale:
    Every price includes postage (which will likely be Royal Mail 2nd class signed for)
    1) ZOTAC NVIDIA GEFORCE 9500GT G96 1GB 128 BIT BUS WIDTH PCI-EX16 DVI
    Im looking for £24 delivered
    Condition:
    Fully working - removed working from my old PC which I have now upgraded
    Comes with driver disc, booklets, card, stickers and box (although this is in average condition)
    *The serial number of the item will be recorded for buyer and seller security, the card will also be marked with a serial security sticker*
    ZOTAC
    G96
    1GB RAM
    128 BIT BUS WIDTH
    PCI-EX16
    2) CORSAIR VENGEANCE RAM 8GB (2 X 4 GB MATCHED PAIR) DDR3-1600
    Im looking for £38 delivered
    CORSAIR VENGEANCE 8GB (2 X 4 GB MATCHED PAIR) DDR3-1600
    Includes:
    > 8GB (2 X 4 GB MATCHED PAIR) CORSAIR VENGEANCE DDR3-1600
    > Original box and packing
    These are a matched pair of RAM sticks, this RAM has been checked with a test program, it was 100% stable with no problems reported and is in excellent working condition.
    8 GIGABYTE (2 X 4 GB) CORSAIR VENGEANCE
    DDR3-1600 PC3-12800 9-9-9-24 240 PIN RAM
    CMZ8GX3M2A1600C9B 1.50V ver5.21 - MATCHED PAIR
    *Sold as seen due to the nature of the product*
    3) Fractal Design Case Arc Mini R2 Black Window FD-CA-ARC-MINI - BOXED
    Im looking for £40 delivered
    Includes:
    > Both drive bays with trays
    > Three Fractal fans
    > Fan speed controller (not sure if this works and never used it)
    > Some screws included (I will include what I can find)
    > Floppy disc bay adapter and plate
    > Instruction booklet
    > Original box and packing inserts
    This case was over £89 when purchased
    Condition:
    The case is in good physical condition. there are no dents, no major scratches, although some very light scuffs may be present on the case.
    There is no Power supply or optical drive included just the case
    The Arc Mini R2 micro ATX case combines excellent cooling potential and build configurability in a compact, minimalistic and elegant chassis design.
    For a case of this size, it offers unmatched possibilities for water cooling components. And with room for up to six 3.5” drives plus an additional two 2.5” drives hidden behind the motherboard plate, you can build a well-cooled PC with ample storage space.
    The Arc Mini R2 is built to last and is filled with smart features such as dust filters, fan controller, space for tidy cable routing, three case fans included and a window side panel.
    Key features
    A compact micro ATX case designed for exceptional airflow and cooling
    Superior water cooling support for its size, accommodating multiple thick 240mm radiators or even a 360mm radiator for an uncompromised cool system build
    Three Silent Series R2 fans included, giving you excellent cooling straight out of the box! 4 additional fan positions are available
    Featuring an integrated three-speed fan controller and USB 3.0 on the front panel for easy access
    Multiple easy-to-clean dust filters designed into the case to help maintain a dust free interior
    Great storage capacity for a mini chassis, with up to six 3.5” drives and two additional 2.5” drives
    Innovative SSD position mounting, using brackets to allow for easy access once your system is completely built
    Featuring a large stylish window side panel to show off your set up in style
    Designed with ample space for easy, tidy cable routing and an overall a neat build
    4) Western Digital 3.5 powered external Hard Drive - Enclosure only
    Im looking for £13 delivered
    I removed the drive from this to fit into my computer so its hardly been used at all (I think twice)
    Includes:
    > The enclosure
    > Rubber drive shock mounts (the blue things)
    > Power mains adapter and USB cable included
    Works fine
    (obviously no Hard drive included!)
    5) D-Link DUB-H7 - 7 Port High Speed USB HUB
    Includes:
    > D-Link DUB-H7, 7 Port High Speed USB HUB
    > Mains adapter
    > USB cable
    (I think I still have the box)
    Condition:
    Lightly used, but fully working 100%
    Was over £25 when new as is a very good hub
    The DUB-H7 is a 7-port Universal Serial Bus USB 2.0 hub that allows you to connect up to 7 USB 2.0 peripherals and devices to your USB 2.0 ready PC or iMac. Providing an out of the box industry standard bus, this pocket-sized device expands your PC and Mac by adding 7 USB 2.0 ports to your system.
    A single Type B upstream port is provided to connect to the host computer, or another USB hub. Configured directly by the operating system, the DUB-H7 operates seamlessly with both Microsoft's OpenHCI, Intel's Universal HCI and USB 2.0 new generation specification EHCI.
    As a standard USB hub, it buffers USB data from any attached peripherals or devices in compliance with USB specification versions 1.1 and 2.0 to provide an invisible extension of the USB bus. Supporting both low-speed 1.5Mbps devices, full-speed 12Mbps devices and high-speed 480Mbps, each port creates a bridge between the peripheral and host computer.
    6) LaCie Starck Designer Desktop external Hard Drive 2TB
    Im looking for £45 delivered
    Includes:
    > LaCie Starck Desktop Hard Drive 2TB
    > Mains cable
    > USB cable
    > Boxed with inserts
    Condition:
    Fully working and hardly used, cosmetically it looks as new, works perfectly. Rarely used (hence the reason for sale)
    Very cool talking piece external drive
    3mm of resistant aluminum casing
    Starck signature LED
    Customizable touch-sensitive surface
    Intuitive automatic backup software
    Product Description
    The LaCie Starck Desktop Hard Drive represents a collaboration between LaCie and world-renowned designer Philippe Starck, who designed our groundbreaking line of “Toaster” hard drives ; This product underscores the importance of developing and creating products that are as functional as they are beautiful ; One of the most remarkable features of the LaCie Starck is its intelligent touch-sensitive surface, which responds to your touch ; You can fully customize the front panel of the LaCie Starck so that it opens the application of your choosing, depending on whether you use a short tap or a long touch ; It’s easy to use and efficient. With its sturdy aluminum casing, the LaCie Starck is one of the most resistant and coolest choices on the market—its exterior provides a sturdy, reliable way to keep it from shock and overheating, making the LaCie Starck completely dependable
    Manufacturer's Description
    7) ASUS P5G41T-M LX Motherboard & 8GB DDR3 Crucial RAM & INTEL CORE 2 QUAD Q9450
    Im looking for £55 delivered
    Includes:
    > ASUS P5G41T-M LX Micro ATX Socket LGA775 Motherboard With I/O Backplate, box, driver disc and manual
    > 8GB - 2 x Crucial CT51264BA1339 (4 GB, PC3-10600 (DDR3-1333), DDR3) matched pair - in original packing
    > INTEL CORE 2 QUAD Q9450 2.66 GHz SOCKET 775 CPU (installed on board)
    > Brand new Cooler Master Pro thermal paste
    Extra:
    Intel CPU cooler (one pin is broken so this is included as a bonus)
    The separate parts alone sell for £70 - 90 on ebay!
    Condition:
    All fully working, I have just upgraded my desktop and removed all these items from it to upgrade. Fully working, really quick and capable machine.
    Description:
    Motherboard:
    ASUS Anti-Surge
    ASUS Turbo Key
    8-Channel Audio
    DirectX10 support
    Express Gate and EPU
    For a great foundation to your everyday computing, take a look at this budget-priced Asus P5G41T-M LX Intel G41 microATX Motherboard.
    Supporting multi-core Intel processors through the 775 Intel socket, this motherboard provides an ideal foundation with potential to ramp up performance and functionality with its overclocking tools and available expansion ports.
    Including onboard Intel GMA X4500 graphics, this Asus P5G41T-M LX Intel G41 microATX Motherboard provides immediate visual capabilities that are ideal for tasks such as photo editing and DVD movies. A VGA connector lets you hook up almost universally to monitors, with other forms of connectivity including eight USB 2.0 ports, PS/2 keyboard and mouse connectors, an Ethernet interface, parallel port, internal IDE connector and internal S/PDIF connector for digital surround sound.
    The P5G41T-M LX Intel G41 microATX Motherboard can support up to 8GB of RAM through its two dual-channel 240-pin DIMM slots.
    A smooth all-rounder for the budget-conscious, consider the Asus P5G41T-M LX Intel G41 microATX Motherboard!
    chipset Intel® G41 /ICH7
    Front Side Bus 1333/1066/800 MHz
    Memory 2 x240-pin DIMM, Max. 8 GB, DDR3 1333(O.C.)/1066/800 Non-ECC,Un-buffered Memory
    Dual Channel memory architecture
    *When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
    Expansion Slots 1 x PCIe x16
    1 x PCIe x1
    2 x PCI
    Storage 1 xUltraDMA 100/66/33
    4 xSATA 3 Gb/s ports
    8) Noctua NH-U12P SE2 Dual Fan CPU Heatsink LGA1156 Socket H B i3 i5 i7 LGA1366
    Im looking for £34 delivered
    Includes:
    > One NH-U12P Fan
    > Spare clips for a second fan
    > mount (please check this fits your motherboard)
    > A few connection wires
    Condition:
    Fully working, cleaned and ready for the new owner
    Was over £67 when new!
    Recommended by more than 150 leading international websites and magazines, Noctua’s NH-U12P series has become a benchmark in premium quality quiet cooling. The new NH-U12P SE2 now comes with one NF-P12 fan for further improved performance and adds support for LGA1156/1155/1150 as well as LGA1366 via the latest SecuFirm2™ multi-socket mounting system.
    9) Seagate FreeAgent Go GoFlex 250GB - external hard drives
    Im looking for £25 delivered
    Includes:
    > USB 2.0 cable
    > Boxed with inserts
    Conditon:
    Fully working 100%, only used a few times
    cosmetic condition is used (few scuffs and scratches)
    10) Noctua NA-SRC7 - fan power adapter - 11 cm
    Im looking for £5 delivered
    1 x NA-RC10 Low-Noise Adapters (Resistor cable)
    brand new not used
    Lower the fan speed using this adapter which will also reduce unpleasant fan noise
    black braided fan power calbe with resistor 110mm long
    4 pin PWM connector to be used with 3 pin and 4 pin computer-fans
    Caution: Do not use one Low-Noise Adaptor with multiple fans. Always use one adaptor per fan
    Caution: Noctua Industria PPC fan are not compatible with this adapter
    11) Deepcool Gamerstorm TF120 12Cm 120mm Cooler Case Fan - 4 Pin Connection (two for sale)
    Im looking for £10 delivered each or £17 for the pair
    Brand new - Purchased but never used as I ended up going with watercooling
    These cost £17 each usually, they are very nice fans.
    Description
    As the latest high-end case fan of DEEPCOOL, the TF 120 series features the unique patented 2-layer blade design to deliver a powerful air pressure. Scientific air channel design within the frame helps reduce noise caused by turbulent flow, while the semi-hermetic Fluid Dynamic Bearing (FDB) solution provides the fan with an astounding 100,000-hour MTBF. The advanced detachable blade designs of TF120 provide additional color options, all of which come with Dust-, Water-, and Oil leakage-proof functions to satisfy DIY enthusiasts aiming to build the best-looking rig there is.
    2-Layer Blade Design:
    Unique patented 2-layer blade design that provides amazing visuals that perfectly match the cycling LED lighting effects.
    Dual Functions:
    The unique blade configuration offers a powerful air pressure.
    Scientific air channel design in the frame reduces noise caused by airflow turbulence.
    Double Performance:
    Semi-hermetic Fluid Dynamic Bearing (FDB) solution to achieve an astounding 100,000-hour MTBF.
    Eliminates interference from electromagnetic (EM) noise as well as audible noise caused by mechanical friction.
    DIY Solution:
    Detachable blade provides additional color options and triple-proof features: Dust-, Water-, Oil-leakage proof.
    12) Noctua NF-P12 Vortex-Control 120mm Quiet Case Fan (three for sale)
    Im looking for £10 delivered each or £25 for all three
    Used but fully working - used for around 6 months in a gaming PC which has now been watercooled
    Will be cleaned up prior to sending as much as possible
    Power Consumption:0.6 W, Fan Bearing:SSO bearing, Rated Voltage:12 V, Air Pressure:1.21-1.68 mm, Fan Diameter:120 mm, Fan Height:25 mm, Air Flow:37.3-54.3 cfm, Rated Current:0.05 A, Rotation Speed:300-1300 rpm, Power Connector:4-pin fan connector, Noise Level:12.6-19.8 dBA, Mounting Kit:Included, MTBF:150,000 hour(s)
    Price and currency: Varied
    Delivery: Delivery cost is included within my country
    Payment method: Paypal gift or bank transfer
    Advertised elsewhere?: Advertised elsewhere
    Prefer goods collected?: I have no preference
    ______________________________________________________
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via private conversation to each other after negotiations are complete and prior to dispatching goods and making payment:
    • Landline telephone number. Make a call to check out the area code and number are correct, too
    • Name and address including postcode
    • Valid e-mail address
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
  2. pop80_uk
    pop80_uk
    Aug 21, 2008
    8,756
    +503
    More pics
  3. wilco1uk
    wilco1uk
    Nov 2, 2006
    259
    28
    +47
  4. pop80_uk
    pop80_uk
    Aug 21, 2008
    8,756
    +503
    Could you do £30?
