Loading my speaker stands info please.
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by JIT, Dec 8, 2004.
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    What should i use in my speaker stands to load them -
    Atacama Atabites - Expensive
    Sand only
    Sand + Gravel
    Also how far should i fill them, i've read that it's best not to completely fill the colum/s?
  2. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    A frequent suggestion here is heavy cat litter as it absorbs moisture. Make sure you use kiln-dried sand as it has to be moisture free. Another is to put in lead shot and then sand - much denser. Lord knows where you get lead shot from though!
    Try a search for "mass loading".
  3. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    Thanks, will do.
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    To a degree it also matters what type of speaker you are using. IMO, smaller, lighter speakers seem to work best with mass loaded stands whereas the heavy speakers work best with lighter open stands.
    Adding to much mass can also degrade (colour) the sound so it is a good idea not to complety fill it with lead etc. Also worth trying mixing different mass materials if possible.
  5. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I've got a bag of dried gravel so will try some of that and see what happens, maybe also add sand to fill the spaces between gravel.
  6. carlymart
    carlymart
    Jan 11, 2004
    562
    northeast
    +18
    try and find a local hifi store selling custom design stands they did have some good filler at a good price
  7. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    Or play sand from Early Learning Centres.
  8. carlymart
    carlymart
    Jan 11, 2004
    562
    northeast
    +18
    or silver sand from B&Q and dry it out on backing trays in the oven
  9. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    Ah, but you don't need to dry out ELC sand. It also sounds better (must be a good quality beach they get it from).
  10. carlymart
    carlymart
    Jan 11, 2004
    562
    northeast
    +18
    but not as good as the custom design filler or the Atacama Atabites
  11. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I think dried sand looks like a good option and not too expensive either.
