loading evolution x
Discussion in 'Xbox Forums' started by stealth_189, Jul 17, 2005.
  1. stealth_189
    stealth_189
    Jul 17, 2005
    5
    alrite im new here.. i recently got my xbox modded wit executer 3CE.. n 120gb HD, 4 sum reason i formated the xbox HD (dun ask y) anyway the problem is that wen i try to load the evolution x dash.. it doesnt load.. obviously coz i formated everythin, wat i did is i downloaded the evolution x dash n burned to dvd, i put it in my xbox drive n it loads up... now the problem i have is i need to copy or put on the evolution x dash on my xbox without havin to always use the cd... if anybody cud help me with this i wud really appreciate it!
  2. rob_finch
    rob_finch
    May 8, 2005
    777
    43
    +95
    The Xbox is booting from the CD or DVD you've burnt the Evox dash to. If it has an App like Boxplorer available, run that and copy all files from the CD to the root of C (as long as there's nothing on C that will get overwritten!)
    Alternatively, with Evox running from CD, you might be able to FTP those Evox files from your PC.
  3. stealth_189
    stealth_189
    Jul 17, 2005
    5
    its a dvd-r cd.. wen i load it to the xbox there is no apps or nuthing on the dash... i think i need to get those seperate... all i really want to do is get the evolution x dash on my xbox without havin to use the cd.. is there any way to do that without havin to do all this ftp ****??
  4. Gary D
    Gary D
    Jan 9, 2002
    7,772
    +827
    dude i'd like to help but i can only read english. i assume you have all 26 letters of the alphabet on you pc? use them! its not a mobile! :D
    Gary
  5. stealth_189
    stealth_189
    Jul 17, 2005
    5
    like i said gary i am new here... n i jus got my xbox moded a few days bak, i jus wanna kno how to put the evolution x dash on my xbox without using the cd, is there any way of doing that?? if i cant il jus ftp it.. to ftp from pc to xbox do i need sum sort of cable to hook up my xbox n pc? if i do wats the cable called?
  6. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Que?
  7. stealth_189
    stealth_189
    Jul 17, 2005
    5
    can anyone help me with this?
  8. Gary D
    Gary D
    Jan 9, 2002
    7,772
    +827
    hi
    as i said:
    je voudrais aider mais je ne parle pas votre langue, désolée.
    θα επιθυμούσα να βοηθήσω αλλά το ι dont μιλά τη γλώσσα σας, θλιβερή.
    我希望帮助但我不讲您的语言, 抱歉。
    vorrei aiutare ma non parlo la vostra lingua, spiacente.
    私は助けることを望むが、残念なあなたの言語を話さない。
    я хотел был бы помочь только dont I поговорить ваш язык, огорченный.
    any of those any good? :D
    Gary
  9. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    you forgot the apostrophe in the don't Gary when you auto-translated it to russian :D
  10. Gary D
    Gary D
    Jan 9, 2002
    7,772
    +827
    your answer:
    너는 파일에 시동 가능할cd/dvd을 위에 필요로 할 것이다. 그것에 그것, 시동을 점화하고 너가 하면 이것을 있으면 하자마자 너가 단FTP상자 할 수 있는 너를 위해 모든 재료를 해야 한다.
    u moet een ISO van de dossiers zoeken.
    thanks Games, i thought it looked wrong - my russian is a little rusty :D
    Gary
  11. rob_finch
    rob_finch
    May 8, 2005
    777
    43
    +95
    You need a cross-over cable, you can get them at any computer shop, even PC World! You have to enable FTP access in the Evox settings though, so make sure that's on you CD.
    There's a disk out called Slayer's Xbox Auto Installer, which will do exactly as it says on the tin. Search around on how to find it, don't ask.
  12. stealth_189
    stealth_189
    Jul 17, 2005
    5
    [Abusive post deleted and member permanently banned].
  13. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Oh dear. Past your bedtime I think sonny. Hop off. Go to be up bright and early for school tomorrow. Finger painting is a taxing business.
  14. Gary D
    Gary D
    Jan 9, 2002
    7,772
    +827
    see you later... pre school is it? ha ha :D
    Gary
  15. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,927
    2
    167
    Birmingham, UK
    +9,662
    Ok, so the yoof has been deservedly and permanently banned after that outburst, but your condescending and insulting posts were not appropriate. :thumbsdow
  16. Gary D
    Gary D
    Jan 9, 2002
    7,772
    +827
