Loading CAM using PCMCIA
Discussion in 'Microsoft Windows' started by Borgen154, Mar 23, 2006.
  1. Borgen154
    Borgen154
    How do I load my T-rex Cam using my laptop´s PCMCIA?
    Do I need a special loader program? If yes, which?
  2. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    There is no program available to load your T.Rex CAM using you laptop's PCMCIA slot.
    You need either to program a loader card & update with that or use a CAS3 programmer to directly update the firmware.
