Lnb
Discussion in 'Satellite TV, Sky TV & FreeSat' started by shugs, Jan 17, 2005.
  1. shugs
    shugs
    I have recentlty installed a new lnb but keep getting no sat signal is being received. There is a 75% signal and strength but 0000 on the last 2 fields. Can you help.
  2. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,448
    Reading
    +172
    Have you powered off and on the box? If so maybe the dish has moved while you fitted the LNB. Was it a quad? Some are heavy enough to make the arm drop slightly.
  3. Cliff
    Cliff
    Mar 17, 2001
    4,714
    137
    Kent & overseas
    +1,855
    Is the LNB in the same position in the bracket? You could try twisting it around so you get the right polorization.
