LNB with 4+ Outputs
Discussion in 'Satellite TV, Sky TV & FreeSat' started by milanlad, Oct 9, 2003.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Is there an LNB out there that has 6 or 8 outputs, and is suitable for SKY systems.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    i have not seen one but you can run 2 Quad LNB's on 1 dish ( not really a mini dish though!!! more feeds often uses a distribution system after 8 lines as it gets more cost effective.
  3. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
  4. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Thanks lynx.
    So, in theory, could you connect -
    1. 4 x SKY+ boxes, or
    2. 8 x SKY digiboxes
    Also, I've heard you can use an LNB called a QUATRO and use it with a SWITCHER togive you more than 4 outputs. Anyone know more about this?
  5. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    From the description '8 output universal LNB allows the user to feed 8 individual digital satellite receivers from the LNB and one dish'.
  6. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    I've done a bit of research about using the OCTO 8 Output LNB - I've been told I should you a 60cm, or better still, 80cm dish.
    If the OCTO is to be used on an exsisting SKY+ dish you would need a different bracket.
    The OCTO would ideally be suited to a Channel Master 60 or 80cm dish as it comes with the correct bracket.
  7. Fernsehman
    Fernsehman
    The OCTO should not be used on a Sky minidish, even if you change the bracket. A minidish is the wrong shape. The OCTO is expecting to "see" a circular area. Also be aware of the weight, which is certain to bend the dish arm.
    Various suppliers stock the "Televes OCTO". I found two right away on Google.
    http://www.sccdistribution.co.uk/
    Unfortunately, this site is asking for a password when I click on "Buy"!!
    and
    http://www.satcure.co.uk/accs/page1.htm
    A bit slow to load but the OCTO is there at £99.95 ++
    Expensive but a lot cheaper than a Quattro and a head-end system.
    Fman
  8. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    Sorry milanlad, i was unaware that the Octo was unsuitable.
  9. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    It's ok lynx, I'm glad you pointed the OCTO out. The only thing is that I would need to buy a different dish, but at least it is possible.
