gualo
LNB skew problems
Location: Evesham, West midlands (35 miles south of Birmingham)
Equipment used so far: -
Receiver: Echolink EL-888 FTA Super+ (purchased solely to set up the dishes but not DVB-s2 Compliant... D'oh)
Dish: megasat 80cm offset aluminum
LNB: inverto Black Premium Selected Quattro 40mm LNB
Distribution gear: Spaun SMS 91809NF multiswitch
Coax: WF100 shotgun
Hello everyone, This is my first foray into the world of satellite TV and it has been a steep learning curve so if I have made any howling errors... be kind - and when you've finished laughing any help will be really appreciated!
Below is a photo of the story so far: -
NB. The photo is taken looking quite steeply upwards so the scaffolding handrail does not actually pass in front of the larger dish. (It is below it)
Preamble: -
The small 60cm dish on the right is aligned with hotbird and my lodger uses it to receive all her Polish channels.
My plan is to replace this dish with two 80cm dishes (one aimed at hotbird 13E and the other at astra2 28E) then distribute the feeds around the house using the multiswitch
As this is my first attempt at messing around with satellite dishes of any sort I thought I would take it one step at a time and so my first step has been to align the dish on the left with hotbird and compare results with the existing smaller dish before moving on to fitting the other one...
The first results I got seemed promising as typical signal levels and signal quality from the 80cm dish seem better than the small one.
I felt a little disappointed about the actual numbers (80cm dish in the west midlands should surely give some pretty high readings) however having read around it seems as though the actual numbers on any given receiver are largely arbitrary and the main point is I saw an improvement. So ready for the next stage then... Or so I thought
Here's where I need some help: -
Before taking down the old dish I did a final comparison only this time I used my lodgers polish receiver to check the HD channels and discovered when tweaking the LNB skew I am getting conflicting sweet-spots from different channels/transponders. Is this normal?
Signal strength is showing 95-99% on everything so I am disregarding that and looking at the quality indications.
TVN HD (TP 11508V) can be tweaked to an indicated 76%ish SQ but...
POLSAT (TP 12264V) then falls to 38%ish
Conversely if I skew the LNB a couple of degrees to favor POLSAT (I then get a rise from 38% to 66%ish) TVN HD then drops to the low 40's.
I realize that without professional Sat meters all these figures are arbitrary and will differ according to varying atmospheric conditions but...
It is as if these two vertically aligned transponders are not in the same plane.
I have currently set the Skew to halfway between the two sweet-spots making a compromise and I await some heavy rain to find out if this is good enough!
Can anyone tell me if this is normal or is it an indication something else might be off?
I have tried a number of things already but there is a danger this post is about to challenge Tolstoy's "war and peace" on the word count so if I have missed out any key information please don't flame me just yet!
Any help or ideas will be greatly appreciated!
Coax: WF100 shotgun
Preamble: -
