I've got a cheap Ross satellite dish from B & Q and it only comes with a single LNB. I want to fit a quad LNB and can find several cheap ones on Amazon and Ebay, but they seem to have a smaller diameter than the 40mm neck of the Ross LNB.
Are there different sizes of LNB neck diameters? Most adverts don't say what size they are but, looking at the quad LNB on my Sky type dish, it seems to be only 30mm or so (can't get to it easily to accurately measure it).
Do Sky dishes have smaller LNB fittings and, if so, is it possible to pack out a smaller one to fit a 40mm fitting?
Cheers,
Ray D
Cheers,
Ray D
