LNB advice
connon
Hello
Any advice apreciated
Sky digibox (TU-DSB30)
60cm sky Dish (old style analogue round dish)
Setup been working okay for 2 years
signal strength goes from 80% to none frequently. Reboot box and get no signal most times. Other times okay
Tried another panasonic digibox and same no signal issue.
Cabling/connection at dish and box looks okay.
Alignment should be okay as getting 70% quality/strength when working.
Suspect LNB ??? Can you advise what type of replacemnet LNB for an old style round analogue Sky dish and arm. end of arm is flat rectangular (2.5cm wide x 1.5cm)
Dont mind if LNB is single/double.
Prefer 0.3db noise but not essential
