LMP mount advice please
Discussion in 'Projectors, Screens & Video Processors' started by martian1, May 30, 2005.
  1. martian1
    martian1
    Dec 30, 2001
    2,233
    83
    Sunderland
    +256
    I am unsure either to get the voguls or lmp mount for my infocus 7200 i think the quality of the lmp looks better but i could have a problem. I want mount pole to attach through ceiling onto a timber frame i have between joists i CANNOT use the large cover that would normally sit on ceiling as it will foul on the joists is it possible to use mount without this cover [i will box it incase we move and i need it] the reason i have pole going through ceiling is that i need projector very close to ceiling to achieve correct height image on screen. Thanks all :thumbsup:
  2. ZippyCat
    ZippyCat
    Aug 9, 2004
    572
    28
    +22
    The LMP cover is only held on with double sided tape and can be removed easily. However, why don’t you just order the close ceiling mount to gain that extra height?
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    I would advocate Andy's LMP mount. It's excellent construction, well made and great value.
    Gordon
  4. martian1
    martian1
    Dec 30, 2001
    2,233
    83
    Sunderland
    +256
    Thanks gordon, yes i am ordering the close ceiling mount but as i said it needs to be even closer, if possible! my ceiling height is only 7ft at max.I think mount is 85mm to mounting plate i want about 60mm or less.
