Hi all,
I just got my LG PK350 but I am having some trouble with the USB playback.
First of all the sound is really low, have to have the volume at atleast 50 to get it to a decent level. When watching normal channels thats WAY to much.
I've played around with settings and tried different USB sticks and different formats, MKV, avi etc.
I also have problems with playback of some specific MKV files, ill post info down here. This wont play at all, just gets messed up colors for a second then it bumps me back to USB main menu.
Down here is an example of a file that plays just fine.
Any help or thoughts would be greatly appriciated.
Code:
Format : Matroska
File size : 1.34 GiB
Duration : 43mn 26s
Overall bit rate : 4 414 Kbps
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=32
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 26s
Bit rate : 3 942 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.178
Stream size : 1.20 GiB (89%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 43mn 26s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 119 MiB (9%)
Language : English
Code:
Format : Matroska
File size : 1.09 GiB
Duration : 42mn 16s
Overall bit rate : 3 700 Kbps
Writing application : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Apr 19 2010 11:58:49
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Format settings, GOP : M=4, N=12
Duration : 42mn 16s
Bit rate : 3 314 Kbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.150
Stream size : 981 MiB (88%)
Writing library : x264 core 102 r1666 d058f37
Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=16 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3314 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.10
Language : English
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 42mn 16s
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 116 MiB (10%)
