Derek S-H
Can anyone help here?
This is my living room doorway:
It was like this when I moved in 12 years' ago and looks like there's never been a door fitted, it's always just been a doorway.
I'm thinking of fitting a door, but it can't be a conventional swinging door as the sofa's in the way and can't be moved. It can't open into the corridor either as I would like to mostly leave the opening clear, and only close it when I'm watching something loud.
I've looked at concertina-type and bi-fold doors, but I don't like the designs.
The other alternative is a sliding door and I found this company online who provide it as a complete kit (minus handles):
www.directdoors.com
And in this example, the sliding track is actually bolted onto the door frame itself:
www.directdoors.com
Though the track looks absolutely enormous and my door frame is only 89 cm wide.
Has anyone else had any experience of covering up a single doorway like mine? Any links would be very much appreciated.
Thanks!
p.s. I know there's a Home Cinema Building DIY Forum on here, but I'm not building a Home Cinema, I just want to cover my doorway!
Internal Sliding Doors - Internal Sliding Door Kits - Direct Doors UK
A fantastic range of internal sliding door kits: sliding glass doors, wardrobe sliding doors and sliding doors as room dividers. The largest range in the UK.
Top Mounted Sliding Track & Door - Richmond White Oak Door - No Raised Mouldings - Bevelled Clear Glass - Unfinished
The Top Mounted Sliding Track System is a sliding hardware system with exposed fittings and comes in a finished Black to create a retro look throughout.
Thanks!
