ngd2710
Hi All,
I'm in the process of a home renovation and before I get past the point of no return with my AV setup I wanted to get the wisdom of the members here! I have just put together a false chimney breast with space for a soundbar (Sony HTG-700) BUT I have got some ability to run cabling to put in a proper setup (having previously had various Onkyo receivers this is very tempting!)
Ideally I want to put the receiver out of the way and there is a decent-sized under stairs cupboard that I can use that backs onto the living room so I think I should be covered on that front but there are a few queries I had that I was hoping to try and get sorted.
- Are there any recommendations on sub wiring solutions? I can easily drill through the wall to run a cable for a sub but wondered if there are any recommended approaches for handling a relatively long run (say around 5m) for a sub?
- Are long HDMI runs carrying eARC suitable? My thinking at the moment is that I can run a cable through the cavity in the ceiling and drop it down through a wall chase and out into the cupboard. This would probably be about a 10m run - would there be any limitations with an extra long HDMI or are there better options with Cat6?
- How do ceiling speakers stack up for performance? I was looking to minimise visible AV equipment in the living room (not my decision
) and have been considering using ceiling speakers. I know they wouldn't be as good as ear level but wondered if anyone had any experience with them at all?
