Live problems, when connecting, please help.
Discussion in 'Xbox Forums' started by DwightSchrute, Dec 31, 2006.
  1. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Had a 360 a few days,
    just having a few problems when playing some games live, mainly PGR 3 and COD 3.
    It reguarly says could not connect to host or other player, and other players cannot connect to you,
    read the intructions about this "port forwarding" but unsure what this is or how to sort it,
    if anyone could help be most gratefull,
    my wireless router is a zyxel prestige 600 series.
    but the xbox is connected to this hard wired if this helps.
    Many thanks
    Eamonn
  2. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Update,
    Done connection test on xbox,
    NAT is coming up strict,
    please please help on how i can change it?
  3. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Gone through the guide that shadowman put up,,
    very very helpfull,
    but still struglling to give my computer a static IP address to put in which it says i need.
    Any help would be really appreciated.
  4. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    have you forwarded/opened ports UDP 88, UDP 3074, and TCP 3074,in either the port forwarding section,or firewall section of the router,or if the 360 is connected through the pc,then in the pcs firewall section.
    that will do it.
    also a static ip should be easy to do,in your router setup.
    my mates router was set up sort of like static ip for the pc was 192.168.1.1,for his DS it was 192.168.1.2,for the 360 it was 192.168.1.3...etc..etc.
    then his default gateway was,off the top of my head,192.168.1.254..the same address for bringing the info up on his pc from the router..
    doesnt your router have an info manual about ip ranges..possibly from 192.168.1.0 right up to 192.168.1.253..just pick one,enter the router address..the xxx.xxx.x.254 address for example,and enter that info in the 360s network section..along with the subnet mask(255.255.255.0)**i think,and also preferred/primary dns server stuff(usually the same as the router address too(so 192.168.1.254,in my mates case.)...
    then for pcs,handhelds, etc,just move on to the next available no.,like.1,.2,.3,.4 etc.
  5. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Thanks for reply,
    still struggling,
    if i follow the link, and do as it says regarding ip address, i cant use the internet.
    When doing the command prompt, Ip config all it brings up
    IP address
    192.168.1.33
    Subnet Mask
    255.255.255.0
    D Gateway
    192.168.1.1
    Name Server (only one)
    168.1.1
    But when i try and enter them into the protocol, to assign a static IP cant use the internet till i put it back to find IP automattically.
  6. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Up again.
    Please someone help,
    im a bit of a internet rookie, but tried following these guides but it keeps coming up strict, im ready to smash the xbox up! lol
  7. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
  8. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
  9. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Shadowman,
    done exactly as you say,
    with the IP address,
    Still coming up strict, when i run a test.
  10. Tezcatlipoca
    Tezcatlipoca
    Jan 2, 2007
    139
    +9
    You shouldn't need to give the PC a static IP - it's the 360 which needs one, as it's the 360 which is being port forwarded to.
  11. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Yeah i done that,
    i done what shadowman said,
    changed the xbox to .100
    port forwarded .100
    Still strict
  12. dhehir
    dhehir
    Jun 23, 2006
    39
    Hi there,
    I had a similar problem and took advise from someone on this forum...
    what I did was enable a DMZ on my router and added the IP address of my xbox (which I had to set up manualy on xbox) to the DMZ opening all ports...
    Worked like a charm...
    Hope this helps...
  13. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Dont think my router has DMZ function allready looked for it.
  14. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Any more ideas anyone?
  15. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    Not really mate, not much else you can do if you've portforwarded and made sure its the correct address your forwarding to.
    Is there a newer version of firmware you can try?
    Failing that.. its probably a new router... :(
  16. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    bump anyway. Not looking good for me. :rolleyes:
  17. Dazzyman
    Dazzyman
    Aug 30, 2005
    1,073
    North Yorkshire
    +88
    I had the same you have to enable unpnp after doing a firmware update.
  18. dan4805
    dan4805
    Mar 11, 2005
    35
    maidstone
    hi all,
    Eamon L i have read your post, i had trouble connecting to xbox live sign up...shadowman suggested it might be because my NAT was MODERATE ( as it turns out it was MS Site, i'm on now ) but i looked into my setup on my router and found i could place 1 connection on a static ip address outside the NAT wall. I assigned my Xbox 360 its own static IP address, entered this in the approriate setting ( putting the Xbox outside the NAT Wall ) and voila, when i tested i was OPEN on the NAT test.
    p.s I have not, and will be connecting my Xbox to any network, just a straight shared internet connection through the router.
    dont know if this helps
    Dan4805
  19. dan4805
    dan4805
    Mar 11, 2005
    35
    maidstone
    sorry all, a bit of a typo error in my previous post.
    i meant to say my xbox will never be networked, because if you are outside the NAT wall you are open to hacking....theres nothing to hack on my xbox so i happy with it being outside the NAT protection.
    Regards
    Dan4805
  20. DwightSchrute
    DwightSchrute
    Nov 15, 2006
    141
    16
    Done it all now,
    thanks to shadowman, you helped me out over on xbox.com.
  21. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    I did?
    Cool, maybe it was one my my tech bots I send out :D
    EDIT: Arr yes, recognise the GT now :)
  22. Beany31
    Beany31
    Nov 23, 2008
    5,138
    Kent
    +587
    I have issues with this...
    I have opened all the ports relevant to this Xbox and have set the Xbox IP to static. I have a ZyXeL Router with PostOffice internet. My NAT still says it's strict, please help. The router model is - P-660HW-T1 v2
