Little help please
Discussion in 'PS Vita Forum' started by istanbul05, Jan 4, 2007.
Tags:
  1. istanbul05
    istanbul05
    May 21, 2006
    2,066
    Manchester
    +106
    Hi, i have decided to buy another PSP after seeing that you can play PS1 games on it now. The problem is i need someone to give me a brief update of basically the last few months and what i've missed. When i had my old PSP, i think the latest Version was 2.5. I used homebrew quite a lot so i know how to install programs etc. I have looked at firmwares such as 3.02 OE-A and B. I have no idea what this is? Also whats the latest version you can downgrade now? On average how big are PS1 games?
    Any update or help is greatly appriciated.
  2. monkey business
    monkey business
    Nov 26, 2006
    3,705
    Manchester
    +437
    hi, the latest firmware is 3.03 which u can not downgrade from at the moment so u won't be able to run homebrew i think.
  3. Vini
    Vini
    Nov 25, 2005
    1,608
    48
    UK
    +66
    3.03 is the latest official fw.
    3.03 OE-A is being worked on - apparently - by Dark Alex (rumoured weekend release).
    3.02 OE-B is the best custom fw available at the minute.
    2.80 (TA-079 to TA-086) is the latest firmware you are able to roll back from.
    PSX Games... well depends... If it was one CD back in the day, then rest assured its under 700mb. Obviously you'll be able to tell just by putting your PSX game in your computer.
    3.03 OE-A is rumoured to have compatability for PSX compression.
    There you go, thats everything I've learnt about the PSP fw's in the last week.
  4. SteveG
    SteveG
    Jan 14, 2003
    1,041
    London, UK
    +92
    You basically need to upgrade to 2.71, then use the generic firmware downgrader to go to 1.50. From there you can install the Dark Alex custom firmware (2.71 or 3.02). Once this is installed you have a recovery console which allows you to downgrade back to any firmware you want, so there's now no chance of bricking your psp.
  5. istanbul05
    istanbul05
    May 21, 2006
    2,066
    Manchester
    +106
    Cheers for the replies guys. So what does this custom firmware actually do? Whats the difference between this and the official 3.02.
    Also when you mentioned "TA-079 to TA-086", is this just the motherboard. Do you just check through the UMD slot to see which one you have? Are all the mother boards between 79 and 89? If they are not, can you still downgrade them?
    If i was to buy a PSP from the internet Eg. Amazon or Play what would the firmware likley to be?
    Many Thanks
  6. SteveG
    SteveG
    Jan 14, 2003
    1,041
    London, UK
    +92
    It allows you to run all homebrew without needing devhook, run ISO's direct from memory stick, play UMDs from any region, roll back to any firmware you want.. etc etc.
  7. SteveG
    SteveG
    Jan 14, 2003
    1,041
    London, UK
    +92
    Its basically the same as the official firmware but better!
  8. Vini
    Vini
    Nov 25, 2005
    1,608
    48
    UK
    +66
    Dunno, but i took the risk at my local Game on boxing day and ended up with a 2.71 TA-082, 2 days later there was a TA-082 downgrader released. Lucky or what!
    From what I gather PSP's shipping with 3.X firmware are still few and far between. Though 2.81 is more widely spread.
    If you're lucky you might get a 2.71/2.80....
    Sony PSP @ £111.75 If the offer hasn't expired.
  9. staffiebull
    staffiebull
    Jan 21, 2006
    377
    stafford
    +8
    got 1 from here and its a 2.71 with TA-O82 :smashin:
  10. Widge
    Widge
    Jan 26, 2005
    3,005
    Manchester
    +132
    Are you a bit buggered if you're bang up to date with the FW?
  11. DPT1976
    DPT1976
    Aug 24, 2005
    750
    43
    Essex
    +101
    If your firmware is above 2.8 then currently you are buggered.
  12. TigerBytes
    TigerBytes
    Jan 5, 2006
    572
    Bristol
    +22
    Can somebody advise where I'd find out where the motherboard reference Is..
  13. Vini
    Vini
    Nov 25, 2005
    1,608
    48
    UK
    +66
    [​IMG]
    Either way as long as the firmware is under 2.80 or under, you can go down.
  14. TigerBytes
    TigerBytes
    Jan 5, 2006
    572
    Bristol
    +22
    Vini
    Nice One, I appear to have a TA-081 Motherboard, all I need to do now Is work out Homebrew, Downgrading, and the rest of It, Fingers crossed.
  15. Vini
    Vini
    Nov 25, 2005
    1,608
    48
    UK
    +66
  16. istanbul05
    istanbul05
    May 21, 2006
    2,066
    Manchester
    +106
    Well i finally got my brand new white psp from Amazon this morning. Was out for delivery by Parcelfarce yesterday but they claimed that the 'recipient' wasn't in yesterday, even though i was in all day. Bloody driver probably couldn't be bothered coming! :rolleyes: So i wake up this morning to find it delivered to my suprise, as i thought they only re-deliver on saturdays for an extra charge (£12).
    Any way i open it up to find i have version 2.60 and non TA-082 motherboard! :arty: Just charging it up now. :thumbsup:
    While reading up on the firmware stuff yesterday i read that the latest custom firmware can support compressed PSX games, but i couldn't find anywhere that tells you how to actually compress the games?
    Also just to double check do i now update to 2.71, downgrade to 1.5, then update to 3.02OE.Can you upgrade directly to 3.03OE from 1.5 or do i have to go through 3.02 A ---> B----> 3.03 OE?
    Many Thanks
  17. DPT1976
    DPT1976
    Aug 24, 2005
    750
    43
    Essex
    +101
    You can go from 1.5 straight to 3.03OE-A. You use popstation to convert and compress PS1 games just check out the readme once you have downloaded the custom firmware.
    http://www.dcemu.co.uk/vbulletin/showthread.php?t=48025
  18. istanbul05
    istanbul05
    May 21, 2006
    2,066
    Manchester
    +106
    Anyone got any tips on how to get gpSP (GBA Emulator) working? I just read the readme and don't really understand it and don't know where to start :confused: . Any help is greatly appriciated. Thanks
  19. moe100
    moe100
    Oct 30, 2005
    129
    +6
    Just a quick question mate, What made you decide to get another psp and not a ds lite. As I'm just about to purchase one of the two and not sure which to go for
  20. istanbul05
    istanbul05
    May 21, 2006
    2,066
    Manchester
    +106
    Well i have had both before but sold them both as they were just collecting dust. But i decided to buy another PSP because of the release of the PS1 emulator and that adds to the games libray of the PSP. Also my favourite game is Pro Evo and its great on the PSP so i went for another PSP. However when i had the DS Lite it was great fun. Each system has their advantages and dis-advantages. You should just look at the games available for each system and base your desicision on that. I'm sure whichever system you choose you will have great fun :thumbsup:
  21. moe100
    moe100
    Oct 30, 2005
    129
    +6
    Cheers buddy:thumbsup:
  22. Vini
    Vini
    Nov 25, 2005
    1,608
    48
    UK
    +66
    Re: gpSP, you need the GBABIOS - google ;)
  23. istanbul05
    istanbul05
    May 21, 2006
    2,066
    Manchester
    +106
    Anyone know the cheapest place to get a 4gb Pro Duo? Don't want to go for eBay as it seems a lot of them are fake. There are some cheap ones on Amazon Marketplace, are these likley to be fake aswell?
  24. staffiebull
    staffiebull
    Jan 21, 2006
    377
    stafford
    +8
    what price you got for a 4gb? i ordered a 2gb on the 28th dec thru amazon marketplace and still ######' waiting for it. despatched anytime from the 2nd to the 16th january. :mad: need it now
  25. ASH1
    ASH1
    Mar 1, 2003
    1,361
    +84
    John, have a look on mymemory.com
  26. staffiebull
    staffiebull
    Jan 21, 2006
    377
    stafford
    +8
    can't find a 4gb there ash and the 2gb is pricey 'Sony 2GB Memory Stick PRO DUO £52.99'
  27. ASH1
    ASH1
    Mar 1, 2003
    1,361
    +84
    Here you go mate, have a look on this page.
    http://www.mymemory.co.uk/Sony-PSP
  28. istanbul05
    istanbul05
    May 21, 2006
    2,066
    Manchester
    +106
    I am considering ordering one off Amazon Marketplace, i haven't ordered it yet. I am just a bit concerned at why they are that cheap and they might be fake. Seems as though the link from ASH1 has Sandisk 4gbs for £77 which isn't too bad.
  29. DPT1976
    DPT1976
    Aug 24, 2005
    750
    43
    Essex
    +101
    I got mine from Emartbuy where the blue Sandisk is just under £70.
    http://www.emartbuy.co.uk/products.php?prodtypeid=15&memoryType=Memory+Stick+Pro+Duo&Filter[reset]=1
    Some good prices on Amazon but like Ebay i would be concerned that they were fake as alot of them don't have the orginal packaging.
  30. staffiebull
    staffiebull
    Jan 21, 2006
    377
    stafford
    +8
    thanks for the link again ash, i just looked at sony cards before :oops:
    not heard of them before stimpy, but look good. are the sandisk cards good? bargain at £70. :thumbsup:
    this is taken from there website
    ARE THE PRODUCTS YOU SELL GENUINE ?
    This is a common question that we get from our customers because some of the prices we have are unbelieveable. Everything we sell is genuine product and comes with the relevant manufacturer’s warranty.
