Little Excel Help...
Discussion in 'Computer Software & Operating Systems' started by samjpullen, Jan 14, 2008.
  1. samjpullen
    samjpullen
    Nov 24, 2004
    3,882
    Keighley, West Yorks
    +142
    Hi guys and gals, need a little help with a formula in Excel.
    The formula is =IF(A6>B6,"HIT","MISSED")
    So if somone meets there target they get Hit and if they fail its Missed...
    This works perfect but i am looking for them to be in different colours, e.g if they Miss there target i want it to be in Red and if they hit there target i want it to be in Blue.
    Is there an easy way to do this ?
  2. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,893
    2
    The Fylde Coast
    +13,534
    Use the same formula (more or less) in the Conditional Formatting options. (except 1 and 0 or true and false, to get the condition to work, instead of hit or miss)
    Format - Conditional Formatting.
    [​IMG]
  3. colinwheeler
    colinwheeler
    Jul 12, 2005
    2,423
    Basel
    +153
    Basically you need to add conditional formatting to the cell. Depending on the value in the cell, then the formatting will change. It is under Home/Styles in the latest Excel version. Not sure where it is in the other ones but have a look in help.
  4. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,893
    2
    The Fylde Coast
    +13,534
    MDX, in what way did PMSonics spreadsheet not work for you? Seems as though conditional formatting was covered in it. :confused:
  5. John
    John
    Dec 13, 2002
    11,624
    +3,289
    More appropriate home
