LiteOn LTD-163 recommendation
Discussion in 'Desktop & Laptop Computers Forum' started by ian_guinan, Apr 21, 2002.
  1. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Thanks to various comments on this site I have just swapped out my Pioneer DVD 115 tray drive for a LiteOn DVD drive. Initially I was a bit sceptical as superficially the drive looks a little cheaper in construction. In playback however it is wonderful!
    Apart from a short spin up to determine the data format of the disk, once it has recognised you are playing a movie it reverts to simple 1x play and is quieter than any other component in my PC (inc. QuietPC power supply, Molex radial fan etc).
    Making it region free is a breeze with a small program available in the 'usual' place and does not involve burning a new hacked firmware.
    It functions extremely well as a CD/DVD ROM drive also and I would highly recommend anyone trying to reduce the noise of their machines to consider these drives. My Pioneer sounded like a Rolls Royce jet engine by comparison!
    Thank you all for the recommendation as this has been bugging me for a while and finally my PC is quieter than my projector.
    Regards,
    Ian Guinan
  2. mps
    mps
    Oct 16, 2001
    1,629
    London
    +58
    May i add also that this drive is value for money at just under £51.00 delivered from www.overclockers.co.uk.
    Regards.
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Other sources:
    http://www.dabs.com - £48 inc VAT and small order surcharge, so knock £2.95 off if you build up the order to over £75.
    http://www.ebuyer.com the're £38 inc VAT, but postage is £10 unless you spend £100 (when it's free).
