Liteon 5006 Vs Pann y E55
Discussion in 'Blu-ray & DVD Players & Recorders' started by INchSHOrT, Oct 29, 2004.
  1. INchSHOrT
    INchSHOrT
    Sep 29, 2004
    115
    16
    What do u think?, TBH Liteon seems more usefull for my ££££s,
    Any1 got one one of these new 5006's?
    And anyone had any issues with the E55?
    THANKS
  2. martinthorn
    martinthorn
    I just bought a 5006 today. First impressions :
    i) easy to set up, took about 15 minutes without consulting
    the manual..
    ii) on my 28" CR, playback quality and recording quality looks
    quite good. Friends remarked that even the 6 hour/disk
    recording quality looked better than VHS with higher quality
    better
    iii) RGB input through the scart does not seem to work.
    Perhaps a firmware upgrade is needed ? It's set to composite
    for now..
    iv) multiregion(region free) hacks on the web work fine.
    v) sounds ok through my 5.1 setup
    vi) cheap : about £188 from novatech
    any questions ?
    Martin
  3. a1bert
    a1bert
    Have got LVW5006 too.
    Dead easy to set up.
    RGB works fine - Sky+ to in scart the out to TV
    ***Not tried any recordings yet though***
    Only problem I can see is the same as 'ruskie' posted earlier in a different thread: The auto widescreen switching doesn't work, even if video output set to 16:9.
    Ruskie, if you read this, did you get widescreen switching sorted????????
  4. martinthorn
    martinthorn
    Interesting. A1bert are you certain that it's RGB and not the
    composite signal that your TV is receiving from the SCART ?
    Before I had the 5006, I had an Aiwa DVD player with
    a SCART connected to the TV. The TV was set to only
    receive RGB (not composite) on the SCART and the
    AIWA set to output RGB. It worked fine.
    When I got the 5006 I set it up to output RGB and did
    not touch the TV settings at all. No signal..
    Only when I set the TV to accept composite through the
    SCART did the signal come through (note this is the
    same cable as used with the old DVD player..)
    I shall continue to experiment.. and perhaps read the manual :)
    Martin
    edit : following a suggestion from another thread, I sent the primary scart output from the decoder to the 5006.
    Previously I was using the auxillary scart socket for the
    recorder and the main one to the TV. Now the RGB works fine with the 5006 for input and output :thumbsup:
  5. a1bert
    a1bert
    Hello.
    It's definitely RGB - the picture quality is the same as (if not slighlty better) the way I have it connected.
    Sky+ (TV Out) to the Input (scart 1) of 5006 then the output (scart 2) of the 5006 to my Toshiba 50" rear projection TV. I am using gold plated oxygen free cables too.
    The only problem I have is getting the 5006 to auto switch when it 'outputs' a 16:9 signal/picture.
    One note though, I'm struggling to get stable recording from the DV connection. Picture freezes or sounds drops off! - It might be the cable though......need to get a better quality one!!!!!
