LiteOn 5005B
Discussion in 'Blu-ray & DVD Players & Recorders' started by KoKelly, Sep 30, 2004.
  1. KoKelly
    KoKelly
    Sep 27, 2004
    19
    If anyone can help me I would appreicate it. I am thinking of buying the 5005 DVD Recorder, but in the review it says that the scart inputs or outputs do not support RGB! What is the effect of this or do i need to worry about it? What is it used for? The review also mentions that it only has an American style analogue tuner! Again I'm not sure what this means, other than perhaps you have to turn buttons to perhaps tune in the channels rather than an automatic search? Tuning is not done very often so this may not be an issue.
    Other than that it seems to be a fine machine. How has anyone found using one of they have one?
    Thanks!
