Liteon 5001
Discussion in 'Blu-ray & DVD Players & Recorders' started by googlybear, Nov 18, 2004.
  1. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    Hello all
    I have purchased a liteon 5001 dvd recorder which i have used with no problems for 2 weeks, there is also a fan on it now and so no overheating problems either.
    My reason for posting is this. Does anyone know if you can upgrade the firmware to that of a 5005 recorder so i can record to dvd+ and -.
  2. Bosco
    Bosco
    Unless it is a + and - compatible machine I don't think that a firmware upgrade will make it so, if that was the only thing that had to be done then I would expect manufacturers would just make all the machines + & - compatible.
  3. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    makes sense but i wonder if the drive can just be replaced with a dual model? has anyone done this or even tried to add a HD instead?
