Lite on DVD Rom and Easy CD Creator 6
Discussion in 'Desktop & Laptop Computers Forum' started by Ron240, Sep 10, 2003.
  1. Ron240
    Ron240
    Jan 3, 2002
    3,612
    Kirkcaldy (but i'm not a Fifer)
    +461
    There is a known problem with using the disc copier part of easy cd creator 6 if you have a lite-on dvd rom(jlms xj-hd165h).
    I have read that upgrading the firmware could sort it,i presently have ch11,the latest is ch12.
    I have looked at the lite-on site but cannot even find any mention of this drive and their contact procedure seems to be unusually complicated.:confused:
    I have also read that another way to cure this problem is to forget about this drive and buy another one. :(
    Has anybody experienced this problem and managed to fix it?
  2. nathan_silly
    nathan_silly
    Why not try another burning app? Plenty around... checkout Clone CD.
  3. Ron240
    Ron240
    Jan 3, 2002
    3,612
    +461
    I agree that this would seem an obvious solution but i am just so used to using and comfortable with easy cd creator that i am reluctant to change.:)
  4. nathan_silly
    nathan_silly
    Have you update the "Engine" & "Easy CD Creator" patches?
  5. Ron240
    Ron240
    Jan 3, 2002
    3,612
    +461
    Yes everything is the latest version - 6.1.1.17
    Ironically the problem does not exist with easy cd creator 5.
    Its to do with the way the drive is read under disc copier in ecdc 6.
    The fault has been reported to be with the drive itself though.
  6. nathan_silly
    nathan_silly
    If the main application works (Easy CD Creator)- does it matter? Use the main app for data CD/DVD's- IMO the CD copier util is not that great... CDRWIN, Clone CD are better exact copy disc copiers.
  7. Ron240
    Ron240
    Jan 3, 2002
    3,612
    +461
    yes everything else works fine,its just disc copier,so its easy enough to work around it.
    It just bothers me when i know something is not working the way it should.
    Thanks for your replies anyway. :)
  8. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Go here for firmware 12.
    I don't have this drive - just know about this great firmware site.
