Listening to headphones problem
jlm32
hi I have Samsung ku6000 tv The wife would like to watch TV with headphones at night while I sleep.
The problem I have it's not showing a headphone jack it as digital out which I use to a soundbar & the soundbar as no headphone output ,
Oh the rear the tv shows this below it only as two sockets which are blue & yellow & have tried plugging my audio cable in to both with no luck.
Can anyone help please.
John7
Those sockets are INPUTS for video sources. They will not output a signal for headphones. Can't answer your question yet, need to look at the specs for the TV..................searching..............
Just had a look at the TV specs on line. It doesn't appear that the TV has any headphone jacks. The only option you have is Bluetooth (wireless) headphones. Alternatively you need to check your Sound Bar and see if that has a headphone jack?
jlm32
The soundbar doesn't have a headphone jack it's just digital & Bluetooth.
Might be easier to buy a new soundbar & put this one downstairs.
Thanks Lee
John7
Easier to get some Bluetooth headphones, I just bought some and they're great!
Or, you could buy a Bluetooth receiver for your existing headphones or a Digital in/Analogue out headphone amp.
