Lipsync problems on MCE
goldeneye243
I occasionally have problems with MCE, where the lipsync goes out on .avi or .mpeg files.
This varies from just enough to notice, to up to a second or two.
It sort of fixes it if I press stop, then resume playback.
Is there anything I can do to make it more consistent?
MacBurp
Regular defrags of your hardrive will help to reduce this problem. I use Diskkeeper to defrag files as they are created, I rarely have this problem now.
regards,
Paul
Synchro
Sometimes, all it takes is a quick drag of the slider on the player (the one which shows your how far through the avi/mpeg it is currently playing).
Drag it back, as soo as an avi/mpeg goes out of sync. It should then be ok for the rest of the play.
