Lip sync ???
Discussion in 'Plasma TVs' started by lukassk, Jun 22, 2005.
  1. lukassk
    lukassk
    Apr 14, 2005
    145
    Any one have the same problem ?? When I am playing almost any movie, picture on the screen is a bit ahead of sound. I tought that lip sync error is when sound is ahead of picture, then you can use some feature on AV reciever or other special device to delay sound. How to get rid of this problem ???
  2. greyhorse
    greyhorse
    Apr 16, 2005
    445
    I have only ever had the problem with sky on my old crt set. You can get delay boxes that will adjust, some good amps also have the feature built in.
  3. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    One word - FELSTON
  4. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    hold up, just re-read your post. Picture *ahead* of sound??? What display and source (connection?) are you using? Do you get it with all sources or just the one?
  5. notsosure
    notsosure
    May 26, 2005
    9
    I have the same thing, pictures ahead of sound on dvds. Thought it was my cheap and nasty DVD player (connected via scart to Samsung CRT).
    Thought a more expensive setup would solve the problem (am looking at PWD7) but it seems even if you splash the cash there are still problems (DVD volume / lip sync / noisy fans / artefacts etc). I feel like giving up with it sometimes!!
  6. dilsher
    dilsher
    Liam??
    one phrase: "Dil connect it up, ya lazy sod!" :devil:
  7. notsosure
    notsosure
    May 26, 2005
    9
    hey dilsher, nice setup.
    do you have to make adjustments every time you watch a dvd to get the best out of it, ie sound, picture, lip sync? or is it only if you are a perfectionist?
    its just that i would be ****** off if i bought all that and then needed to buy a felston just for dvds to be watchable. im hoping a pwd7 with an amp, progressive dvd and canton cd1s will do the trick, as i am not fussy do you reckon that will do? or once ive started down the home cinema road is there no turning back!
  8. dilsher
    dilsher
    notsosure mate
    Really all depends on how good your link wiv av amp is etc..and set up!
    On mine i only need to use it for a few Sky channels but never for DVD .
    DVD is perfect wiv one memory..but its all so easy to adjust frm your chair via the remote if channels are all different !!!
    The Felston is worth the money as its a signal issue not a plasma issue
  9. k0rn
    k0rn
    FYI, I asked Panasonic about this and they told me that the Panny PV500 delays around 60ms.
    I think you can spot it quite easily though 60ms isn´t a huge delay.
  10. notsosure
    notsosure
    May 26, 2005
    9
    cheers dilsher
  11. lukassk
    lukassk
    Apr 14, 2005
    145
    I am using denon 1910 via dvi cable ( good quality one Cambridge). My plasma is Nec VR5 ( very pleased with PQ :thumbsup: ) This bug doesnt bother me so much but my girl friend is complaining all the time. Sometimes its all right for some part of the movie but then its happens again. As I said before the picture is few frames ahead of sound not other way around, so Felston wont ma ke any difference in this case.
  12. nheather
    nheather
    Oct 6, 2004
    15,259
    Horsham, West Sussex
    +4,437
    lukassk
    Just to clarify, you say the picture is ahead of the sound.
    The normal lip sync problem is the sound being ahead of the picture. This is because it takes longer to process the picture than it does the sound. This is what the AV delays and the Felston attempt to address.
    But your problem is the other way round so an AV delay or Felston will just make matters worse.
    I see your problem (picture ahead of sound) quite often but only on Sky. What's more it varies from day to day and channel to channel so there is not a lot you do even if you had means to delay the picture because amount of delay changes so often.
    Cheers,
    Nigel
  13. lukassk
    lukassk
    Apr 14, 2005
    145
    Nigel -
    Yes !!! I can see that you understand my problem. That is true this error varies form dvd to dvd, even when I am playing same dvd sometimes it is not so apparent. Me thinks that it have something to do with picture processing on dvd player, when I am setting output to 720p problem is more noticable than on regural progressive scan. I will try another DVD player (Yamaha) via component maybe that will make any diffrence. I was just thinking, if that will be a problem with dvd player, anyone knows any shop who let me demo player at my home before I will buy anything ?? ( maybe Sevenoaks S&V ) ???
  14. Mep
    Mep
    Dec 25, 2004
    9,551
    +472
    7oaks do if they have a demo model (i had their 2910 for about 5 weeks before i bought one).......you have to pay for it but they'll give you the dosh back if you don't like it.
  15. notsosure
    notsosure
    May 26, 2005
    9
    thats worrying lukassk as i was hoping decent kit would eradicate the problem. i was considering the denon 1910, maybe i'll just stick with a limit 900se via component.
    i get exactly what you decscribe, on DVDs not sky, and it varies on different DVDs as well as through the film. I use rental DVDs but dont see how that can be the problem. It'll be interesting to see what you find from your Yamaha via component
    cheers
  16. tutu
    tutu
    Apr 28, 2004
    2,217
    48
    +58
    I've just purchased my first amp - Cambridge Azur 540R to go with my PV500. Should I be concerned that it doesn't have an audio delay function? :(
  17. Eitzel
    Eitzel
    Nov 3, 2004
    654
    46
    Top Secret-Anyone coming anywhere near my Pioneer
    +143
