lip sync ?????
Discussion in 'Plasma TVs Forum' started by claire handford, Feb 7, 2005.
  1. claire handford
    claire handford
    Have just purchaced a new panny TH37PW from av sales :smashin: NO remote / 240v lead ect ect :mad: i hope this is not a demo screen !!
    Anyway back to my questions. I have a panny dmr50 dvd recorder, and a pace twin view, i have a scart ( rgb ) from the pace to the panny recorder and then from the recorder to a rgb to vga converter(js tech) and then vga to the screen (phew) dvd pic great,freeview best i,ve seen ! :clap:
    The rgb to vga also has phono audio out , which i have run to a denon 1804.
    This is to make it wife freindly as i can leave the amp on and use the volume on the pace remote as well as change channels ect. I get lip sync probs on freeview but not on dvd ? But whats really done me is that i don,t get any probs when playing back material archived on the pace hard drive :confused:
    And i could swear the pic looks better when rcordered to have drive and played back. you will all prob be :boring: by know but 1 last question, is there a way to check how many hours my screen has been run for ? This would tell me if it has been used before ............
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    if its same as pw7 you hold down volume- on screen and press status button 3 times on remote(one under standby button) choose SD, shows you two figures the first (WT i think) is times turned on and the second (pt) is hours watched.
  3. claire handford
    claire handford
    Thanks i,ll try this , if and when i get a bloody remote !!
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    oh yes..good point...sounds most unlike av-sales I'm sure they will sort you out quickly
