lip sync problems with PS2
Discussion in 'Playstation Forums' started by flukeskywalker, May 19, 2005.
  1. flukeskywalker
    flukeskywalker
    Mar 22, 2005
    110
    I have my PS2 connected to my Panansonic home cinema set up (getting on a bit) via some simple phono leads (the black and red jobbies) but I'm getting a serious delay with sound through my speakers.
    When I turn the volume up on my telly, the sound is fine! but if i switch back to the home cinema setup, the delay is there again. Its quite significant, about half a second.
    Any help would be appreciated, ta!!
  2. moopig
    moopig
    May 29, 2005
    3
    Bristol, UK
    Try pressing pause and then play. I seem to remember that helped when I used to use my PS2 as a DVD player and had the same problem.
    moopig
  3. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    Is the sound delay with games or movies or both?
