Lip sync problems on Pace Freeview
Discussion in 'Freeview & YouView' started by SeeNoWeevil, Nov 20, 2004.
  1. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    Seems to have started since the last software update (the one listed as providing support for top-up tv)
    A reboot fixes the problem but it is v annoying.
    It is the small wedge shaped pace box.
  2. Smith2004
    Smith2004
    Mar 28, 2004
    1,508
    +162
    I am having the same problem with this Pace box, Speedsix. It happens on all channels, but usually ITV1 and Channel 4, and frequently occurs after a 'static' sound is heard. The volume also drops as well after this sound is heard. Changing the channel (and then back again) sometimes fixes it. Also the BBC1 picture via this box is quite poor compared to other channels, but undoubtedly this is something to do with the bit rate and not the fault of the box itself.
  3. Adam Gilchrist
    Adam Gilchrist
    It's the Topup TV update. I returned mine to Pace, who downgraded the software. It's fine now.
  4. cwoj
    cwoj
    pace told me that they should have a new update soon that fixes the problem
  5. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    Hi, I have had the 'update available' pop up at least 3 times but when I click ok it says 'no update is available at this time' or something similar, and no software is downloaded.
    Very annoying.
  6. x6461
    x6461
    Jan 9, 2005
    62
    +16
    Hi you need to differ the update until 3 am by pressing the blue button when prompted for the update,then ensure you leave the DTVA on and tuned to BBC1 overnight,this update is just really a patch for the software you are all ready running so thats why it says that no update is available if you just press ok .It fixes the lip sync and some other issues.
    Hope this helps
  7. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    Thanks!
    So when I pressed ok the patch wasn't actually applied and I must tell it to wait until 3am, as I am still having the lip sync issues?
    They should still increase the version number regardless of it being only a patch imo.
    Thanks for your help
    Dom
