Lip Sync problem
Discussion in 'LCD & LED LCD TVs' started by hawkipa, Sep 22, 2005.
  1. hawkipa
    hawkipa
    I have just bought a sony DAV LF1 home cinema kit to go with my Sony KDL-L32MRX1.. Ive noticed their is a problem with both the lip sync and display. Has anyone any advice on whether I should just accept this or if there is something I can do.
    Thks
    Paul
  2. scarty16
    scarty16
    Jul 1, 2003
    1,058
    +97
    Lip sync can be caused by the disk being incorrrect in eth first place.
    Or the time taken to process screen iamge is longer than time required to process sound, hence delay.
    Get an amp/receiver with lip sync correction built in that will sort you out.
