Lip Sync on marantz
Discussion in 'AV Receivers & Amplifiers' started by deanym, Apr 1, 2005.
Tags:
  1. deanym
    deanym
    May 29, 2004
    1,789
    +141
    I have an old marantz sr5200 - works fine and dandy for me and I'm not looking to change it as my priorities are music and this amp just looks after home cinema.
    The question is, does this amp have a lip sync correction feature?
    Thanks.
  2. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    I'm pretty much 100% sure it doesn't, it's an older model and i'm not even sure any receiver had it back then, even now you'll only find on the more expensive receivers.
  3. deanym
    deanym
    May 29, 2004
    1,789
    +141
    Thanks for the reply,
    I thought so, but it was worth checking just in case!
    Cheers.
  4. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    By the way, the newest/cheapest receiver that do have lip sync are the marantz 5500 and the yamaha 650.
  5. deanym
    deanym
    May 29, 2004
    1,789
    +141
    Excellent - may have to start having a wee look at a new purchase!!
    Thanks for the info - very useful.
