P
P3450
If this has been posted aready my apologies.
I can convert DVD to MP4 and then onto my 1Gb memory stick. I use DVD shrink and 3GP converter. I'm firmware is 2.71 ithink.
The problem and it's not every time, is some lip sync issues ie there approx 1/2 to 1 sec out of sync with the actual audio sound.
I've done TV programmes and DVD and it varies so there is no constant pattern.
I do try to only do the conversion with nothing else running so the computer has the max amount of processing, RAM etc to play with.
Anybody got an ideas at all how to combat this or as to why it happens.
Thanks for the advice it's greatly appreciated
