Lip Sync issue with JVC DRMH30 DVD recorder??
Discussion in 'Blu-ray & DVD Players & Recorders' started by Tape Slack, Aug 23, 2004.
  1. Tape Slack
    Tape Slack
    Hello,
    I wonder if any AV'ites can help me. I've just received my JVC but when it comes to playing back off the hard drive, there is a definite delay in lip sync. Is this a common thing with HD's or am I missing something?
    I'm pushing the output via a very convoluted set up. I've got a signal coming thru my Sony Freeview box into the JVC then out into a modulator (embarrassed to say my TV doesn't have a scart - ex COOP rental circa 1979, with lovely mock wood surround) then into my TV. Could this be the outrageously obvious reason? It seems fine when I record onto VHS
    Any clues gratefully received.
    Phil
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,859
    Warwick
    +2,781
    Are you sure it wasn't the original broadcast that had lip-sync issues? It happens quite frequently.
  3. Tape Slack
    Tape Slack
    I'm almost certain this isn't the issue. I recordeded Nip & Tuck Channel4 which had awful delay, then the thing with Trevor Eve in as a detective, which had the same??
    Thanks for replying so soon by the way.
    Phil
  4. madmatt
    madmatt
    Lip sync from broadcasters is within close limits, then the consumer messes it up with a long chain of boxes, the audio usually gets ahead of the picture
    Instead of a colour test card, they should broadcast a clapper board for us!
  5. jac12
    jac12
    This is NOT a broadcast-problem. A lot of people have experienced this problem with the JVC DRMH30 .
    JVC has been contacted about this problem.
