Lip Sync Compensation Is A Must!
bluesfan
Amps with Lip Sync compensation:
Denon 3803/3805
Pioneer AX3/AX5/AX10
H/K 430
Any more?
That is, sound delay compensation when the sound comes out but their lips don't move (well not for a half second or more).
These amps are a must if you are getting a plasma screen in the future, have Sky or your dvd player is crap.
mutley
rotel's 1056, 1067 (i think)
bluesfan
I think Arcam also do a DVD player with delay features?!?
When will sound delay be available on cheaper stuff?
Jeff
Which can do different lip sync settings per input or at least have different presets? Very important IMO.
The other thing to worry about is how much delay is allowed, Meridian G68 only supports 30ms which isn't enough, you need 60ms at the very least.
Galaxy
And unless the delay facility is easily accessed it would be more trouble than its worth, I know for a fact from Sky+ some programmes can suddenly "aquire" lip sync errors, after the adverts they are fine, or from channel to channel the errors can appear randomly. Its a Broadcast error.
If you are going to have to keep adjusting the delay access easily from the remote would be preferred.
Best regards David
D
Dalorp
Your right. The 3803 was next to useless for me. For 99.9% of programmes there was mo lipsync. When some appeared by the time I had gone through the menu system to correct it I had missed half the programme. Ended up not bothering.
Jase
Denon A1SR and Upgraded A1SE have 0-200ms Audio Delay per Input.
Denon 3803 and 3805 also have this on a per input basis.
Bear in mind the Audio Delay is ONLY accessible if the incoming signal is Digital or is converted to Digital (then back to Analogue) with a mode such as Dolby PLII.
For Sky etc don't blame the unit as the delay time needed varies from channel to channel.:rolleyes:
bluesfan
So why does everyone buy the 3803? Both ax3/ax5 & hk 430 allow adjust 'on the fly' via the remote. This is what is needed!
Jase
Because of it's performance I would assume.:) You adjust the Audio Delay via the OSD which is pretty easy, although I agree it would be handy to do it via the remote (or front panel) as well.
probeski
Excuse my ignorance but can someone please explain step by step what you have to do to get into the OSD with the Denon 3803 or the 3805 (which is what i want). Do you not access the OSD via the remote?
AcademicBarzo
Yamaha DSP-AX750SE also has delay feature - 0-160 milliseconds, if I remember correctly.
Ed Selley
AVF Reviewer
Since when has Jase been a guest :confused:
A
Arcangel
Make sure the remote is set to AMP. Connect a cable from the Monitor Output to your display (either S-Video or an RCA Composite cable). Press the SETUP button on the remote and you should have access to the main setup menu. You can adjust AUDIO DELAY from there. If you want to adjust the DVD input for example, then make sure you have selected that input before you press the SETUP button. The audio signal must be digital or be converted to digital (using a mode such as Dolby PLII) to be able to use the AUDIO DELAY feature.
probeski
Thanks. Are there heaps of sub menus to navigate before arriving at the audio delay feature or once you get the hang of it can you adjust the audio delay quite quickly (just in case each programs video timings differ)? Surely it's not so hard that i should be thinking of a different receiver?
Cheers.
A
Arcangel
Cheers.
Depending on the model there are usually a couple of pages of settings ranging from Speaker Setup, Delay Times, Channel Levels etc down to the Audio Delay, Digital In Assignments etc. It's very easy to navigate around. Don't get too hung up about changing the Audio Delay for each channel as you'll go mental. I find 60ms tends to work well for most Satellite Channels. :)
If you want to get the best out of the amp make sure you set it all up properly with regard to the Speaker Setup, Channel Levels, Delay Times (speaker distances from where you sit). :thumbsup:
RoughRider
It's a bit of a dinosaur but my Yamaha DSP-AX1 has this, 0-99ms all channels, 0-30ms and 0-60ms trim for centre and surrounds respectively, although not input specific. Still, no excuse for anyone else not to these days.
Cable seems to be as bad as Sky for lipsync, I wouldn't even bother trying to correct it.
probeski
I plan on running Foxtel Digital (Au) upscaled via a HTPC to a plasma so i'll probably need the audio delay feature. I have foxtel digital via satellite at the moment running only through a tv and don't notice any lip sync differences between the channels. With Sky Digital are the differences between the channels -with regard to lip sync- exaggerated depending on the system being used; are the differences noticeable when using nothing but the tv and Sky digital STB?
jayss
Sorry if this is a daft question, but is this conversion done by the amp or does it have to be done before feeding the signal to the amp?
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
Latest News
Sony unveils Inzone gaming brand
  • By Ian Collen
  • Published
Bowers & Wilkins launches Px7 S2 wireless headphones
  • By Ian Collen
  • Published
AVForums Podcast: 27th June 2022
  • By Phil Hinton
  • Published
Netflix confirms ad-supported option is on the way
  • By Ian Collen
  • Published
