Lip Sinc Prob
Discussion in 'Plasma TVs Forum' started by Hicksy, Jul 27, 2004.
  1. Hicksy
    Hicksy
    I wonder if anybody can help. I have recently purchased a Samsung PS42V4SX 42 in Plasma TV which seems very good value. However, now and then i receive lip sinc problems when viewing cable.
    I currently link my cable box to my tv and also to my AV (for the sound). Should I be linking straight to my AV from my TV?
    Not an expert clearly!!
    I also have DVI connections on my Plasma for video.
    Suggestions much appreciated.
    J
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Connecting audio out from the TV might help in this case, though it is clearly not going to do the biz if you have the problem with DVD, no dolby digital. The audio may be deliberately 'delayed' in the plasma works to cope with the slow video processing. It's a well known problem with plasmas various. If not, there are AV amps to cure the trouble, like the denon 38 series (3803's are cheap now, out of fashion), or there is an external box built by the guy in the sticky above, the aspect switcher man, to do audio delay.
  3. Hicksy
    Hicksy
    cheers mate
