Lion King SE (R2)
Discussion in 'Movie Forum' started by huwg, May 24, 2004.
  1. huwg
    huwg
    Oct 23, 2003
    1,851
    +121
    Hope someone can shed some light on this.
    On the back of the box it states that there are 2 versions of the film. I can only find 1 - the new extended version (including the song 'the morning report').
    Are they including the 'sing-a-long' version which is the same, but just pops up subtitles for the duration of the songs? - if so, that is hardly a different version. A bit like saying 'follow the white rabbit' is a different version of the Matrix.
    I'd have thought the extra version is the original one, if so where is it?
    Cheers.
  2. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    A bit odd this, but if you go to soundtrack selection you can choose the original without the sing-song, just talking. Play that soundtrack to get the original (or as original as possible on DVD).
  3. huwg
    huwg
    Oct 23, 2003
    1,851
    +121
    Cheers,
    I'll give it a try.
  4. Kevo
    Kevo
    Aug 23, 2001
    5,395
    Manchester
    +147
    Isn't the original version on Disk 1 and the 'ext' version on Disk 2.
  5. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Nope, you access them in the way I've described. Believe me, our two year old is obsessed with this bloody film, it's probably been played twice a week since it's release!!!
    It's an illogical way to do it though I'll grant you.
  6. Kevo
    Kevo
    Aug 23, 2001
    5,395
    Manchester
    +147
    That's probaly why I missed the ext version!
