Linux LiveCD (or LiveDVD) distro for an ageing 7 year old HP laptop
Discussion in 'Computer Software & Operating Systems' started by davemurgatroyd2, Jun 2, 2018.
Tags:
  1. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,599
    Oxford
    +1,334
    Can anyone recommend a Linux LiveCD (or LiveDVD) distro for an ageing 7 year old HP laptop and a pensioner newbie to Linux and where to download an iso for it?
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    23,882
    Poole
    +9,262
    What spec is the laptop? CPU, RAM etc.
    Linux Mint is good, has lots of extras in the distribution and the documentation tells you how to install it.
    https://linuxmint.com/download.php
  3. DavidG1
    DavidG1
    Jul 5, 2016
    197
    West Yorkshire
    +35
  4. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,599
    Oxford
    +1,334
    Processor is a dual core T4300 2.1 ghz with 3 GB RAM.
    HDD is defunct at this time (Smart Drive fail) and was 250 GB but as this laptop was rescued by a friend at a late relatives house clearance minus a couple of covers (HDD and WiFi modem) I wanted to check it out with a LiveCD to make sure everything else he needs is working OK - sound, network etc. Replacing/upgrading HDD is not a problem if it is working enough to make it worth while - surfing net, playing video/music files etc
  5. next010
    next010
    May 29, 2005
    10,689
    163
    +2,084
    Have a look at distro watch they have category for old computers, antiX and Puppy linux are meant for real old machines, probably a fair bit older than yours.
    I'd guess linux mint should run fine from a USB drive with your hardware, use this tool to take the mint iso image and make it a bootable USB drive which can run the live version of mint.
  6. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,599
    Oxford
    +1,334
    I have now found two Mint isos- LiveCD and Ultimate LiveDVD. They run very well on this laptop.USB is not an option here as only 2 USB ports needed for WiFi dongle (WiFi card missing) and digital cameras and DVD drive is not needed for playing CDs and DVDs. This is only a temporary solution to check out lptop functions fully but will fit replcement HDD, re-install Windows 7 on it and then give friend option of dual booting to choose netween OSs.
