Linux help
Discussion in 'Desktop & Laptop Computers Forum' started by Stereo Steve, Jan 14, 2005.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    I've been mucking around with Mandrake 10.1 recently and like it a lot. I'm trying to build a multimedia PC with it as an OS and so far it's going OK. However, when I click 'Turn off the computer' it starts to shut down and then just sits there with the bar 95% of the way across. Is this an OS issue or is it a hardware issue? Clciking 'reset' works fine.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Sounds like some process has got stuck shutting down, could be a pain trying to discover which one. Which Window Manager are you using?
  3. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    On googling thoroughly it seems this is common with Mandrake 10.1 and some Via chipsets and there is a setting you have to change in the Kernel somewhere. Not had time to play with it yet but I think it's solvable.
  4. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    I had this on 10.1 on the PC in the kitchen and it is gone on 10.2 (at least I haven't seen it the three times I've turned off the machine). No idea what it was, but since I never turned the machine off it wasn't a hassle.
    Greg
