LINN speaker plugs
Discussion in 'Home Cinema Buying & Building' started by pbickley, Oct 30, 2004.
  1. pbickley
    pbickley
    Dec 2, 2003
    Hiya,
    Does anyone have any advice as to which is the best way to connect the new style speaker plugs ?
    It appears you can either pierce a hole in the end and connect through this hole, or break off the tab and connect in from the side.
    Cheers,
    Phil.
