Linn Komponent 120 Sub Under Bed!
Discussion in 'Arcam Owners' Forum' started by Greggles, Aug 1, 2005.
Tags:
  1. Greggles
    Greggles
    Mar 15, 2005
    1,070
    St. Saviour, Jersey
    +74
    I have been toying with the idea of setting up a second home cinema in the bedroom (sad I know), but the main stumbling block has been where to locate the sub. I was wondering if anyone has seen/heard the new Linn Komponent "Bass Reinforcement Speaker" which, at only 5.5 inches high, could fit under the bed!
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,556
    Edinburgh
    +1,265
    I have heard the Komponent range of speakers and have to say I was not overly impressed with them. The main sepakers were ok, I liked the standmounters best but the subwoofer was not very good at all.
    The main problem with the subwoofer was that it didn't go very low, it seemed like there was a whole range of frequencies missing at the bottom end but I guess that's the price you pay for it being so compact.
    It's probably best for you to go and listen to it yourself and make your own mind up, you may find it's just what you're looking for.
  3. scarty16
    scarty16
    Jul 1, 2003
    1,355
    +295
    :thumbsup: Did the earth move for you
