Linn Knowledge needed!!
Discussion in 'Hi-Fi Stereo Systems & Separates' started by gunizzle, Jun 14, 2005.
  1. gunizzle
    gunizzle
    Anyone with Linn Knowledge out there???
    I am about to make a few Linn purchases namely (CLASSIK and 2 x KATAN speakers)
    my question is this, how do i plug my TV into this so i get the best sound out of it??? whats the correct connection / cable to buy and what socket does it plug into? its a Panasonic 37 inch PW7 that i want to run - i will also be running sky + and a DVD player most probably direct into the TV.
    Do i have those 2 going direct into the socket board then something from the board out into the CLASSIK??? is that how it works??
    HELLPPP!!!!! www.complete-amateur.com!!!
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Quite easy dude, looking at the manual there are 3 inputs to use :
    http://linfo.linn.co.uk/binaries/8166B8DA-C3B7-46E6-8614836BEAD9DE46/CLASSIK_Music.pdf
    Aux, Tape 1 (In) Tape 2 (in) in addition to the Tape 2 (output) and the Preout (For PA usage) :
    The Classik – Katan pairing is a lovely match FWIW, I would easily live with one, you may want to at some point conisder using a sub in tandem with the Katans (via the Classiks pre-outs & Subs low level connections) would make an excellent system, plumbing those bass depths.
    So from your Sky box (Audio RCA output) with a pair of RCA-RCA Interconnects to the Aux input connection for TV & Sky. Then your DVD-V player again with a set of RCA ICs into the Tape 1 input for DVD-V use, buy a couple of sets of ICs like these to get started :
    http://www.tvcables.co.uk/cgi-bin/tvcables/PGA4201.html Or ask your Linn dealer to throw in some free ICs & some Linn LK20 speaker cable and your off dude.
  3. gunizzle
    gunizzle
    Cheers mate!! WICKED!!! ill post some pics of the setup once ive got it going!!
