Linn Knekt amps faulty
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by northernmunki, May 20, 2005.
  1. northernmunki
    northernmunki
    I have two faulty Linn Knekt amps and my mate wants me to fix them, they power on and light up by I dont get any sound out of them. Is this a 'known' issue, what can I do?
  2. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    When you say "Knekt" amps, do you mean Knekt Roomamps?
    If so, do you have an RCU (Room Control Unit) plugged in? If not, I don't think you'll get anything out of it, as you have no control on source selection or volume. It may well be set to remote audio rather than local anyway.
    Rowland
  3. northernmunki
    northernmunki
    Thanks for the reply. Yes they are the room amps. RCU works fine, as i've done a direct swap with another and all is good.
  4. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    Sorry if I was pointing out the obvious! :)
    Other than that I don't really know, I'm afraid. I'm a user, rather than a dealer/maintenance guy...
    The one thing I do know is that Linn have a fixed price repair service. Obviously your mate would like you to fix them on the cheap, but £150 (which is what I've been charged to have my AV5125 repaired) is a lot less than a new roomamp!
