Linn Keilidhs - How to convert Active to Passive?
Discussion in 'Home Cinema Speakers' started by Simon78, May 20, 2005.
  1. Simon78
    Simon78
    Apr 26, 2005
    91
    Stamford
    Guys - anyone able to provide a simple explanation of what is involved in the process of changing an active Linn Keilidh back to passive - I am afraid I need laymans language - though my brother will be completing the task and is much more up on the technical aspect so I may be able to just show him any answers
    Many thanks
    Simon
  2. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    Hmmm...I'm actually looking to do the opposite myself soon. Shame we don't live that near each other, otherwise we could just swap speakers!
    As I understand it, there's a link inside the cabinets (between the banana sockets and the passive crossover) which gets cut when converting from passive to aktiv, so I guess that you need to remake it. Unfortunately, I'm not sure which this link is...
    I seem to remember hearing that the difficult bit is actually taking out the main speaker driver, as you do this mod from the front of the speaker, not the back.
    Hope that helps. Is there any chance you could take a few pictures when you do it? This would help me when I come to do passive > aktiv.
    Thanks,
    Rowland
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,998
    +2,802
    Take out the bottom mid driver.
    Unscrew all the six 4mm sockets to allow you to pull the passive crossover out the hole where the mid unit is.
    You should see the instructions on the passive crossover of how to convert to aktiv. Do the reverse. Two speaker cable wires need de-soldered and moved back to where they were and there may be licks to get remade as well but it's been a long time since I've done it....
    Gordon
  4. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    Cool. Thanks Gordon. Now I just need to wait for my AV5125 to come back from Linn and then get hold of some Aktiv cards...
