Linn AV5125 5 channel power amp
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Matt F, Dec 5, 2001.
  1. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Hi, has anyone out there managed to audition Linn's 5 channel power amp? I haven't noticed any magazine reviews of it.
    Retailing at £1750, I'm curious as to how it compares with the other 5 channel power amps out there i.e. is it worth the extra grand or so over the Rotel THX amps (985MKII/1075)? and how does it stack up against the more expensive TAG and Bryston offerings?
    Matt.
    :confused:
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The AV5125 power amp is very capable. It will supply 125w RMS 8ohm per channel with a total of 500w RMS at any one time (ie 5x 100w).
    It is very good sounding, and much better than the Rotels etc in stereo.
    I've only heard it as a apckage with Linn's Av5103 preamp, and an install last week with an MK K-series speaker system it sounded amazing!
    Well worth it.
  3. richard greene
    richard greene
    Jul 28, 2006
    2
    Manchester
    I have a Linn Unidisk SC and was going to buy an AV5125 would this be a good match ?
    Can I connect digitally ? or only analogue ? would I be able to play SACD discs fully ?
