Moncy
I have a linn system 2 active 5140s with 3 amps, 2 Katans, 1 center speaker, powered by 2 amps. All controlled by a 5103. The 5103 is toast, Linn repair said all the capacitors are bad. I want to at least use my 5140s. So my question is, how? Should I convert them to passive and use a different amp, and if so how? What other ideas do you have?
