Linksys Wireless Router And X-box Live
Discussion in 'General Video Gaming Chat' started by JUNKYARD DOG, May 20, 2005.
  1. JUNKYARD DOG
    JUNKYARD DOG
    Recently bought a linksys wireless g router and wireless gaming adaptor to use on my x-box because of pc being downstairs and x-box upstairs. I've followed the instructions on how to set it up but i still can't can't get it going. My first stumbling block is setting the router up with the pc so i can go on the internet. Any advice would be helpfull (so would detailed instructions) :)
  2. jenic
    jenic
    Dec 10, 2004
    2,907
    83
    +180
    What router is it? If it is the WAG54G them i would advise you to return it because they are very unreliable.
  3. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,937
    2
    Manchester
    +4,457
    Yeah, Junkyard - if you say which router model you have and where you're up to configuring it, I can help maybe - I have a Linksys G router and gaming adapter also.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    they arent that bad, (WAG54G) if it is a version 2 you are fine i had a buggy V1.1 but touch wood the V2 is very stable and reliable. i know others who use them and mostly they are fine require the odd reboot but what doesnt?
  5. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    mines lovely :D and works like a dream :D
    Gary
  6. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    did you ever upgrade the firmware mine work for me
  7. Tetlee
    Tetlee
    Jan 21, 2004
    20,266
    Taunton
    +4,765
    Sorry to ask an obvious question, but how do you upgrade the firmware? I have my WAG54G in the lounge with my pc connected in the bedroom via wireless card, does the upgrade do anything to help range/connection as my pc connection seems a bit tempremental and tends to drop.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    instructions are on linksys site, if you go to linksys.com there is a live chat help, very useful, for firmware upgrade use wired connection, down load file turn router off take it up stairs and hard wire to PC and run upgrade.
  9. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    I have one of these and have never had any problems with it. Its been switched on an running uninterrupted for around a year. However if you are having problems setting it up I would recommend returning and getting a dlan setup, It works out cheaper than the router and gamming adapter, is plug and play so no setup issues and you get much better performance for gamming.
    Personally I didnt find the performance of wireless anywhwhere near acceptable in my house over two floors for Live, it worked but there was lag.
  10. Rambles
    Rambles
    Jul 14, 2004
    8,309
    UK
    +1,285
    Whats a dlan set-up? I am on the verge of getting an xbox and want to connect it wirelessly to my existing wired network for streaming media files....
  11. Ryderage
    Ryderage
    Feb 1, 2005
    75
  12. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Thats the one. If you do a search on the forums there is a thread on the Devolo dlan setup.
    Its a good alternative to wireless for Live and online gamming, much better performance and its cheaper. Just need to make sure the rooms you want to share your connection on are on the same power circuit.
  13. Rambles
    Rambles
    Jul 14, 2004
    8,309
    UK
    +1,285
    Well thanks Rikki :smashin:
    In fact with google there is no need for us to help each other out on these forums at all...... ;)
    Anyway it's only 14mbps - no good for streaming media.
  14. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Its fine for streaming media as long as its not HD ! Also remember that wireless is not great for video for the same reason as gamming. Packet loss = unwatchable :(
