I used to have my Linksys Velop nodes configured as Automatic DHCP, with the primary node connected by Ethernet to a router (a TPlink TD9980) which was acting as an ordinary NAT/DHCP router. To avoid double-NAT problems, I've now put the Velop system into bridge mode which turns off its NAT and DHCP, with those functions being performed only by the router.
Everything appeared to be working fine, but I've just noticed that nodes which used
to connect automatically to each other now have to be turned on one at a time, when (with
a couple of exceptions) the same nodes in the same locations used to connect
automatically if the system was rebooted or all the nodes turned on at the
same time after a power cut. Failure to do this means that all/most of the nodes stay in flash-red state.
Also, the Linksys app, talking to the Velop network, does not give "disconnected" indications
for other nodes so there is no easy way to tell whether a node has gone offline, other than by
walking around and looking at the lights - or waiting for people to say "there isn't a good
signal in this room".
This came to light because I accidentally turned the router off (I dislodged
its PSU from the wall socket) and so the Velop had nothing to talk to. All
the nodes had then gone into flashing-red-light mode and simply rebooting
the primary node did not fix it.
Does bridge mode affect the ability of nodes to talk to each other and to
handle the common situation where the nodes are positioned far enough away
that they are just within the limit of 5 GHz connectivity, which means that
there is a lot of overlap of longer-range 2.4 GHz and therefore competition for free
channels. It's a crying shame that the Velop nodes can't have 2.4 turned on
selectively so it's only on for the nodes which have devices nearby that
cannot talk 5 GHz.
cannot talk 5 GHz.
